VFB for batch render?
    I'm using build 16265. Not one of the "stable" builds but seems to work ok so far.
      It should work in the nightly builds. Will check to see what happens with the stable ones.
        I just installed the latest stable nightly, v16073, and the VFB did not show during batch render. Vlado, do you have any plans on updating the nightly stable anytime soon with this feature?
        We are one week from a big project where we would benefit from this feature.
        Best Regards,
        Fredrik
          As I said, I will check what happened there.
            Many thanks.
            Best Regards,
            Fredrik
            • #21
              Bumping a super old thread. Anyone know if VFB shows up during batch render? Im rendering on my own local machine, and was using "render sequence" to batch render my shot while seeing it in the VFB...but that behavior seems to have changed in the latest nightly....which Im trying to use since it saves out LUTs. One thing added, one taken away!
              Website
              https://mangobeard.com/
              Behance
              • #22
                Hey, this is an old thread, indeed.
                Can you get me more details on what you're after?
                The VFB does not show up during batch rendering.
                However, any color corrections set up for the VFB can still be applied to the batch render output (depending on your settings).
                For LUTs specifically - what exactly do you need to do?
                And most importantly - what V-Ray (and Maya) version(s) are you running?
                Alex Yolov
                Product Manager
                V-Ray for Maya, Chaos Player
                www.chaos.com
                • #23
                  Hi. I was hoping I could remote login into a slave machine I have which is used only for rendering, and see the VFB while it renders shots I send to it via deadline, from my main machine. Currently Im using the latest Maya nightly and Maya 2020.
                  Website
                  Behance
                  • #24
                    Unfortunately, that's not possible.
                    If you're doing maya batch rendering, the VFB is not created and you can only see the image once the render completes and writes it out.
                    Alex Yolov
                    Product Manager
                    www.chaos.com
                    • #25
                      ok, good to know, thanks for the response.
                      Website
                      Behance
