Vector Displacement ?
  • Vector Displacement ?
    Hi there,
    couldn't really find a clear answer to the support of vector displacement.
    - supported for vray maya ?
    - if so, is there a specific vray vector disp attribute to use ?
    thx a lot,
    bernhard
    www.bernhardrieder.com
    rieder.bernhard@gmail.com
    Vector displacement is supported; you need to add the V-Ray displacement control attributes to your shape node and select "Vector" or "Vector (absolute)" as the displacement type.
    If you are going to use OpenEXR textures for that, you might also need to turn on the "Allow negative shader colors" option, either in the global V-Ray settings, or for the particular File texture.
      thank you very much vlado for the info, appreciate that !
        Here is a short tutorial on rendering vector displacement from Mudbox with V-Ray for Maya:
        http://www.spot3d.com/vray/help/maya...splacement.htm
