Is it possible to add VRay attributes (available at the shape node of a geometry under attributes > VRay > .....) like the subdivision, displacement quality, displacement control, etc. for multiple selected objects at once? I don't want to hit "3" to turn all objects in the scene into sub-d surfaces and control the displacement quality globally via the Render Setting menu, but just control the displacement of certain objects (still quite a lot) in the scene.
Also, if in default setting, is it more efficient and less memory consumption to render geometries as smoothed surfaces via adding subdivision and displacement control for each of them or just hit "3" (check "Render viewport subdivision") before rendering?
cheers,
Jason
cheers,
Jason
