Quick Question - Hidden objects - slow down renders ?
  • Quick Question - Hidden objects - slow down renders ?
    Hey guys,
    A very quick one this.
    Do you know if lots of hidden geometry can slow down the rendering, or have an impact on memory ?
    Nothing bad is happening but I was just curious.
    it would be pretty easy to test your theory.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      Yes theoretically but not for me at the moment - computer locked down in 2 hour render
        Me, too
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Depends... Have u unticked option to not render hiden objects?
            Yeah I'm pretty sure in my presets I have it set to that, along with the hidden lights.
            Will know a bit later on though.
              if you simply delete the hidden geometry/lights and try rendering, does anything change? if not, then its probably something else. Check your dynamic memory limit (first thing to check)
              Dmitry Vinnik
              Silhouette Images Inc.
              ShowReel:
                Hi Dmitry,
                As I mentioned it wasn't a case of noticing any problems, just a hypothetical question that I thought perhaps someone would know.
                Obviously I'll try a test when I can.
                  Hey guys.. I just wanted to share that with a new build of V-Ray its always best to NOT use any pre-existing render presets. I ran into issues in production using old presets with new builds.
                    Cheers for the heads up, I tend to make the presets per-thing I'm messing around with.
                    Good to know anyway
                      What issues?
                      Is this something we can fix?
                      /Teodor
                      V-Ray developer
