no textures rendered in RT
  • no textures rendered in RT
    In our office, we all have the same problem which is that when doing an IPR with Vray RT it does not take the textures into the rendering. When we do an normal rendering it works fine. We are using V-Ray 2.0 for Maya 2011. Does anyone know how to fix this?
    I have had the same issue with RT here, and sometimes it stops refreshing or won't load.
    V-ray 2.0 maya2012 here
    -DM
      If you look at the V-Ray RT server console window what does it say regarding the textures?
        Hi Vlado,
        I am not sure what it says in the console ( I guess this is the window with the black background), as it does not show up any longer. It did at the beginning, but now it doesn't anymore and I don't know how to open it.
        This is what it says in the output window:
        [2011/Dec/15|13:39:29] V-Ray: Exporting scene to V-Ray.
        [2011/Dec/15|13:39:29] V-Ray: Parsing light links time 0h 0m 0.0s (0.0 s)
        [2011/Dec/15|13:39:29] V-Ray: Translating scene geometry for V-Ray
        [2011/Dec/15|13:39:29] V-Ray: Total time translating scene for V-Ray 0h 0m 0.1s (0.1 s)
        [2011/Dec/15|13:39:29] V-Ray: Rendering with IPR (port 20207).
        [2011/Dec/15|13:39:29] V-Ray: Updating frame at time 1.00
        [2011/Dec/15|13:39:29] V-Ray: (Estimated time remaining: 0h 0m 0.2s): 42 % completed
        [2011/Dec/15|13:39:29] V-Ray: Total time updating frame 0h 0m 0.2s (0.2 s)
        [2011/Dec/15|13:39:29] V-Ray: Render complete
        [2011/Dec/15|13:39:29] V-Ray: ========================
        [2011/Dec/15|13:39:29] V-Ray warning: [SettingsPNG] No image writer specified.
        [2011/Dec/15|13:39:29] V-Ray warning: [SettingsJPEG] No image writer specified.
        [2011/Dec/15|13:39:29] V-Ray warning: [SettingsSGI] No image writer specified.
        [2011/Dec/15|13:39:29] V-Ray warning: [SettingsTIFF] No image writer specified.
        [2011/Dec/15|13:39:29] V-Ray warning: [SettingsTGA] No image writer specified.
        [2011/Dec/15|13:39:29] V-Ray warning: [SettingsEXR] No image writer specified.
        [2011/Dec/15|13:39:29] V-Ray: Preparing renderer...
        [2011/Dec/15|13:39:29] V-Ray: Preparing scene for rendering...
        [2011/Dec/15|13:39:29] V-Ray: Creating texture cache with size 0 MB
        [2011/Dec/15|13:39:29] V-Ray: dr host: 127.0.0.1
        [2011/Dec/15|13:39:29] V-Ray: Connected to render host 127.0.0.1
        [2011/Dec/15|13:39:29] V-Ray: Using 1 hosts for distributed rendering.
        [2011/Dec/15|13:39:29] V-Ray: Preparing scene for frame...
        [2011/Dec/15|13:39:30] V-Ray warning: Scene is empty.
        [2011/Dec/15|13:39:30] V-Ray: Running RTEngine
        Regards,
        Sebastien
          You don't see the console (yes the black window), because you have the vray render slave enabled.
          You can disable it by going to the services settings dialog and then disable the VRayMayaSpawnerXXXX (where XXXX is the version of Maya).
          Then you can start V-Ray RT again and the console should pop up.
          After that you can right click on the console and use the mark menu option.
          /Teodor
          V-Ray developer
