Have you removed metaballs in a later build? Iḿ 99% certain I found and tried them about a month ago through the vray create menu, but now I can't find them anymore.
Metaballs
Originally posted by vlado View PostThey were still there last time I checked. They are only in the nightly builds though, not in the stable ones.
I checked the release notes for the latest version (build 22029 from yesterday), and I don't see anything about metaballs.
Cheers.
I noticed the folder ./vray_geommetaball in the samples/vray_plugins folder in the latest nightly, although there was only a make file there. Any chance of the source code showing up in the next build?
/EricImportant Looking Pirates | ILPVFX
http://www.ilpvfx.com/
I can send you the source code privately if you email me to vlado@chaosgroup.com; I don't want to include it in the builds just yet.
Originally posted by vlado View PostI can send you the source code privately if you email me to vlado@chaosgroup.com; I don't want to include it in the builds just yet.
Originally posted by alainfx View PostNeither of their Release notes include Metaballs, so I don't know if it's available in the current "stable" nightly build.
I installed the latest nightly, to test the Metaballs, and found it only works with particles (it crashes maya if you render while the positive set includes a geometry or a locator).
Is it scheduled to add locators to the supported types ? (I guess it's not more difficult than particles).
And poly mesh ? (ok, that one is probably a lot more difficult).
Sometimes it's easier to setup locators than particles (you could get a metaball between 3 cream drops using simple keyframes).
Cheers.
For the moment we don't plan to support locators or other geometry; you'll have to make the particles go in those locations (f.e. by distributing the particles on the surface of the geometry).
Originally posted by vlado View PostFor the moment we don't plan to support locators or other geometry; you'll have to make the particles go in those locations (f.e. by distributing the particles on the surface of the geometry).
I have written scripts to constrain particles to locators positions, but it's not ideal.
Do you plan to have the particle's radiusPP attribute control the radius of each blobby element ?
It would be very useful.
EDIT : sorry, I didn't saw there is a "Use particle size" switch, it works all right.
Also, on the area that joins 2 particles, there is a visible band (see picture below).
Is it something that I can avoid by tweaking the shading ?
(maybe it's just how blobby should be, I'm not sure)
Thanks.Last edited by alainfx; 07-08-2012, 05:01 AM.
