IPR Render Performance
  • IPR Render Performance
    Hello,
    I was curious to know about speeding up the IPR render for Vray for Maya 2011 in Windows 7 64 bit.. I"m running Vray 2.0. I have been testing the IPR method on 3 exact machines with the exception of the grfx cards... Machine 1 has an nvidia quadro FX 5600, Machine 2 has an nvidia quadro FX 5800, Machine 3 has an nvidia quadro FX 6000..
    There really doesn't seem to be too much performance gained with this even on the higher grfx card? I would think that with the newer and faster cards the performance would be dramatically different on the same scenes especially since we see a huge difference in Real time performance on other real time apps?
    Are there any settings to change to allow the faster gpu and on board proc/ram kick in?
    Thanks,
    Did you switch to the OpenCL engine in the first place? If you are using the CPU engine, of course there won't be any difference.
      Yes, I switched that setting but there still doesn't seem to be any faster performance?
      I was curious to know if there are hardware accelerator options in Vray settings or the Nvidia control panel settings or even in Maya that I was missing?
        If you look at the V-Ray RT render server window, does it show that it is really using the GPU?
