emissive material scattering
  • emissive material scattering
    Hi all,
    Trying to get fastSSS to scatter some emissive materials (think bright led sources embedded in something... fat, skin, fluid..)
    Test image shows 2 separate cylinders, lit with one area light.
    thin cylinder with vray light mtl (hot green) intersecting a fatter cylinder that has a blend between:
    base: stripes of the same vray lightMtl (hot green)
    coat material: FastSSS material set to default "pink skin"
    (basically trying it both ways: to test inter-object scattering and single-object, multiple materials)
    also tried putting the color blend upstream from the fastSSS and plug it into scatter color and subsurf color, to no avail (as opposed to blending 2 materials).
    update: switching the single scattering to raytraced, seemed to work for the inter-object scattering.... that, and -not- using RT
    still no luck with the texture based approach.
    any and all ideas welcome!
    You might have more luck using the sub-surface options of the VRayMtl material for this, rather than fastsss2.
      Hello,
      Thanks for the suggestion. here's a picture of the previous setup (with fasts SSS tweaked to work) and the VrayMtl with glossy refractions.
      Both are "working" for the inter-object scattering.
      Could not get the translucency to work for self illuminated stripes on the VrayMtl though. is there a secret handshake?
      The parameters seemed pretty self explanatory.
      thanks for all the help!
        Would something like this work?
          looks great, that will get me going, thanks.
          There is another, more complicated component to the question, but I'll follow up when I have more to show, always nicer to chat around a pic.
          thanks again!
          -c
