VRayParticleTex
  • VRayParticleTex
    Hi all,
    Could someone explain how to use the VRayParticleTex node?
    I've tried the obvious (adding a particle system to the phxpartsys_set) and playing with the settings, but nothing changes in the render...
    I'll be missing something obvious, but there's no documentation for it, thanks!
    Ian
    This is a texture from PhoenixFD http://www.spot3d.com/phoenix20/partext.htm
    Here is an example phx_parttex.zip
    You can hide the plane, enable the fog, and disable the shift in VRayParticleTex1 for a second example.
    V-Ray/PhoenixFD for Maya developer
