glow and neon in vray maya
  • glow and neon in vray maya
    Hey there,
    Do anyone knows how to make a glow object in vray maya ? a kind of vraymtaerial light+glow around it?
    Didier
    If you use the nightly builds, there are lens effects in the V-Ray VFB for glow/glare. For the official builds, it might be best to add these effects in a compositing application.
      thx vlado,
      I ll get the version ASAP and let you know how it goes
        Hey Vlado,
        My pipeline td is asking if we where we could get access to the nightly build for One Of Us ( we are clients of chaos group ).
          Yes, please email us to vraymaya@chaosgroup.com and our support guys will arrange it.
            Vlado,
            can we expect this stable nightly 2.1 release to have the glow/glare feature in it...
            vray_adv_21001_maya2012_linux_x64_21575.rar
            Or should we be using this more nightly....
            vray_adv_22501_maya2012_linux_x64_21613.rar
            Thanks
              For now the lens effects can be found only in the nightly builds.
              Zdravko Keremidchiev
                Unfortunately, no. The feature required quite a few changes to our VFB code and I can't merge it safely into the current stable builds.
                These will work, but of course they might not be as stable...
                  Hey!
                  I got some trouble to connect object to environment fog like in the documentation:
                  http://www.spot3d.com/vray/help/150S...entfog.htm#ex1
                  Is it possible that someone explain me how to use and object as a gizmo with envfog in maya vray?
                  Didier
                    You can download the actual scene from the link here: http://www.spot3d.com/vray/help/150S...turbulence.zip
                    Basically you need to set "Opacity map" option of the geometry (which you will use as a gizmo) shader to black and set "VRayEnvironmentFog" node in the "Volume Material" slot of its shading group.
                      The other option, which might work better if the camera goes inside the gizmo is to use the Relationship editor to link the VRayEnvironmentFog to the objects that you want to use as gizmos.
                        thank you , but actually , Im using Maya, not max... Do u have the same scene in maya vray?
                          Here is a simple example scene. The yellow cube is done by setting the VRayEnvironmentFog via the sahding group of the geometry material and the red one via the Relationship editor.
                          I hope that helps.
                            thanbk you very much!
                            • #15
                              i have the glow working in the vray frame buffer
                              but is there a way to have it as a render element in batch rendering?
                              glow and bloom doesnt come up in the render element list and also is not renderer as a seperate pass.
                              tx
