Velocity Pass, Z-Depth & Refraction
  • Velocity Pass, Z-Depth & Refraction
    Hi guys,
    I've run into a bit of a problem where I don't know if I'm doing something wrong or if it really is broken.
    I have a ufo/spaceship with a big glass dome over the cockpit, and I have characters inside moving around and talking.
    I'm trying to use the velocity pass for motion blur on the characters and space ship but when I render the velocity pass and the z-depth pass, the areas which are being refracted go completely nuts;
    The values in the both passes go off the charts, but only in the refracted areas. If I turn the glass off all the values are normal and I can use both passes perfectly.
    Anybody got any thoughts or experience with such problems?
    Cheers,
    Greg.
    It worked fine on my test. But you don't get proper zdepth through refraction anyway. Why not just render the glass as a sep pass?
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      Are you using the 22035 nightly?
      Yeah I've been doing something similar to get around it, but it gets a little tricky with reflections / secondary reflections / refractions and the last part...render times. The idea behind getting these passes to work is so I don't need to effectively re-render the same image over again just for one element.
      -Greg.
      EDIT: I also have a failsafe, RSMB blur, so this isn't a project breaker by any means. I'd just like to know if this is a bug and if I can rely on simplifying things to this level for future applications
