Vray for Amazon
  • Vray for Amazon
    Heya
    I got a little problem. The way Vray works for maya with DBR is that it packs the scene and send to slaves every time I hit a render. Now that is fine for local networks but it wont work for Amazon servers since vray would upload the scene to each instance which would take ages... Now this wont work so I'm writting here to see if there is a way for Vray to use References ? I got all my scene and textures on amazon instance so all I'm using at home is reference scene. Any chance to get it working? Or install maya on amazon servers and then use vray&maya like max&vray ?
    For small scenes its pretty cool boost. Here goes 5 instances with my home network... Also is there linux version? The linux instances are 16/32 cores so its pretty tempting to get it to work on my end... Click image for larger version
    Thanks, bye.
    V-Ray for Maya has a Linux version of course - it's available from the download section on our website.
    Other than that, I understand what's the issue, but I don't have an immediate solution for you right now - we could not get Maya to work in the same way as a DR slave as 3ds Max. That was way back though - it might be possible now and we could maybe look into it.
      Also, you could cache heavy geometry as .vrmesh files so that they are not part of the scene itself... of course, it's not quite the same thing.
        What you mean .vrmesh? I never really used them so will have to read some docs about it. As long as I can apply render overrides on it and put to different render layers(so it work as reference) I could tweak my workflow with cars at least to work for it.
        edit: ahh u mean proxy... yea I guess that could work ! As long as I can put displacement on it to smooth it out but then again... maybe I could just export it as heavy geometry... will have to look in to it
        Thanks, bye.
          Heya
          An update on the thini...
          I remade my scene in proxies and synces with amazon servers. Now that went smooth and instances pick up within 2 minuts render data.
          The weird issue I have now is that they dont go 100% and spawn all 32/per instance buckets. My internet if at low end with usage so I'm not sure where the issue is, is the maya limited? Vray ? or am I missing something...
          I'm attaching few screenshots.
          The buckets seems to show up and disapear... weird stuff is happening!
ID:	846201Click image for larger version
ID:	846202Click image for larger version
          I'm running 5 instances + me so its in total... 176 bucketz...
          Thanks, bye.
            It might be useful to check the output from the render slaves on the cloud.
              Heya
              Yea I will have to run the myself not as service I think. I did not get any vray icon when they were rendering, only process...
              As to them appearing and disappearing. It looked like I was limited to around 1-2 slaves that could run at max speed. Which distributed across 5 pcs or 2... it was very random. Strange, it felt as if my workstation was not sending enough requests to render and it was taking a lot of time to send the request. Sometimes a slave pick up and 30 buckets spawned instantly. Then when they render they just disappear and did not show up again. My network was at around 10% with upload speeds so there is bandwidth to use if need. Is maya limited or anything like that? I'm using latest nightly I think... whh
              Will try it again at some point with vray started manually and I'll see whats going on.
