bentNormal
  • bentNormal
    Hi,There.
    I would like to get "bentNormal" pass with Vray for maya.
    I can do it with vray for 3dsmax.
    I use vrayDirt with environment occlusion mode on and I use NormalVec of vraySamplerInfo as GI Environment map.
    And I did same way in maya,but I cannot.
    How can I do with maya and vray?
    Thanks.
    masahiro.teraoka
    Can you post your shading network in 3ds Max?
      here is some screen shots.
ID:	846772Click image for larger version
ID:	846773Click image for larger version
      Kind Regards
      masahiro.teraoka
      masahiro.teraoka
        Thank you for posting the example shots.
        Unfortunately we are still working on this workflow with bent normals for V-Ray for Maya.
        I will try to keep this thread updated.
        Tashko Zashev | chaos.com
          Heh, it's amazing that it works (somewhat unexpected )
          You can set up the same thing in Maya though; you can add extra V-Ray attributes to the samplerInfo node, and one of the V-Ray outputs is the normal in world space. Unfortunately there is a bug in TexDirt that prevents this from working properly, but it is fixed for the next nightly build tomorrow.
            Actually no need to fix anything; you can use the "rayDirection" output of a samplerInfo node as the GI environment...
              Ha, this sounds awesome! I´ll check that out tomorrow. The good thing is, I have still one channel left in my special passes render Love it!
              VFX Supervisor @ www.parasol-island.com personal website www.dryzen.com latest reel http://vimeo.com/23603917
                Hi,Vlado.
                Wow,I can get in maya with "rayDirection" you said!
                Great.
                Thanks.
                masahiro.teraoka
