PTex vector displacement on subdivisions
  • PTex vector displacement on subdivisions
    Hi guys,
    After battling issues with UVs seams for quite a while, we finally found a way to make PTex vector displacement to work well on subdivided surfaces with deforming meshes. No UVs needed at all!
    Some tests:
    And one more:
      Hi Vlado,
      It is really Great!!! I love it!
      Thank you for all your efforts!!
      Best Regards,
      Sangho Jung.
        it seems that horn is extended by 2nd test movie.
        Is it the correct result?
        OakCorp Japan - Yuji Yamauchi
        oakcorp.net
        v-ray.jp
          great!
          is it a worklfow thing or did you fixed something in the code.?
            Originally posted by flat View Post
            it seems that horn is extended by 2nd test movie. Is it the correct result?
            It's anyone's guess I can change it, but the current implementation seemed better for cases where you have wrinkles and such. For example, if the model is bending, you'd expect the displacement to squeeze at the bend... I'll try to post some examples later.
              nice. now all you need is to get Pixologic to support PTex
              Dave Girard
                vlado could you give some insides how this is working.?
