Material Select per Light select ?
  • Material Select per Light select ?
    Heya
    I'm scratching my head to see if its possible.
    I have 10 lights in my Light select pass, what I want to do is to use Material Select as a shader source for Light Select pass. So atm I have mtlBlend which screen 2 shaders together. Now I want to get render pass per each of those shaders per each light I have in scene.
    So in total I get 20 render passes, 10 for each shader.
    Is it doable or I have to set up 2 render passes?
    Just curious if I mist something.
    Thanks, bye.
    That sounds like inception with vray.
      I think you need to setup 2 renderLayer, and each output those 10 light select elements.
      The reason being even if you can evaluate 2 shaders properly, light select element will return combined result.
      So 2 render layer/pass would be easier to setup, and I don't think you can do it all in one.
        Heya
        Inception ftw watched it last night! - Coincidence?!
        As to 2 layers, yea that how we have it now. I just wonder if I can get it down to 1-2 render layer per job instead of 3 atm. Funny with MR it took us 25 render layers!!!
        Love Vray, forever and ever!
