Hi
I'm trying to write some extremely basic mel scripts to speed up my workflow when creating shader networks. Basically just copying commands from the script editor and adding a few string variables here and there, so that i can build my favourite shader networks at the touch of a shelf button.
However the vray nodes don't seem to work. For example if i try
shadingNode -asTexture VrayDirt
sometimes it works, other times it doesn't. Even though all i've done is copy it from the script editor history!
also i don't seem to be able to use 'textures from plugin' (for example compMaxtex or FalloffTex)
is it actually possible to do this? should I give up? or are there correct procedures to use to ensure vray nodes are correctly loaded with mel?
thanks
thanks
