Hi guys, I am a little confused as I usually use nuke.
What is the workflow to get files out of Maya + Vray & into AfterEffects correctly. I have googled some locations but the end result in the preview has even more banding.
I am using AE CS6 with Vray 3.0 & Maya if that helps any. Rendering openEXR files at 16bit.
I would use "Project Settings" and select 32 bits per channel and pick sRGB IEC61966-2.1 for "working space". And than i'll tick linearize working space.
Everything renders with MASSIVE banding after that.
In summary - I want to know what is the correct way to get my linear files into AE and work linearly and output as 2.2 gamma. Thanks!
