OSL texture common coordinates space
  • OSL texture common coordinates space
    I'm having trouble getting world position in SOL texture shader. What coordinate space P is?
    I thought that a simple implementation like below will give me world position but the results are not what I expected.
    point p = transform("common","world",P);
    result=color(p[0],p[1],0);
    Am I doing something wrong here? thank you.
    The P is in world space. Also common is the same thing as world, so the transform call won't do anything.
    Probably you don't see what you're expecting, because you don't set the P[2] to the blue channel of the output.
    Here is an example shader that is exactly the same as the worldPosition render element
    Code:
    shader worldSpace(output color out=color(1,1,1)) {
    	out=color(P[0], P[1], P[2]);
    V-Ray developer
      it is not in word as it doesn't "stick" to the geo. When I move the camera the values slide on the surface. it only works when my camera is aligned with Z.
      Thank you for confirming that is is supposed to be in world space and that it should work that way.
      Code:
        In V-Ray for Maya, the "common" space is not the same as "world" space. It looks like we are not doing the transformation between the two properly - will make a note to fix it.
          Indeed there is a mismatch between the "common" and "world" coordinate spaces.
          I cannot come up with a workaround, sorry.
          The problem is fixed for the next service pack.
          Best Regards,
          Ivan Mavrov
