Hi
Hoping someone can help out here.
I'm rendering some product shots of several different objects and different angles, so i have 3 render setup layers, with some material overrides etc.
VRay seems a bit wonky in working with Maya's new Render Setup system - or is it just me?
If i deselect master layer, and set the 3 layers to renderable. And then start vary (not batch) then it just renders the one layer which i'm on or is visible in the viewport.
If i under the render menu and render sequence option choose render all layers, it renders the layers, but 2-3 times each layer. I accentially discovered this, when i saw is go back to frame 01 and render again - but in the same layer that had just finished.
Is there a special work around when using VRay or ?
Version: Maya 2017u2, VRay 3.4.06 (official stable build)
OS: OSX 10.11.6
OS: OSX 10.11.6
