vray 3.4 blend material two refractive materials broken
  • vray 3.4 blend material two refractive materials broken
    Hi trying to use a blend material with two refractive materials, it seems to be broken, only accpets the base material even when set to fully coat material on the blend if you set the coat material to non refractive then it works.
    Update, appears to be when you have a fog color in the refraction.
      or refraction color,
        Could you try to render this in 3.5? I think it should be fixed there.
        V-Ray for Maya dev team lead
