vrayobjectproperties Primary visibility and Exclusion lists
  • vrayobjectproperties Primary visibility and Exclusion lists
    In the vrayobjectproperties, 'Primary visibility' for lights isn't working. Geometry placed in the vrayobjectproperties reacts fine.
    Exclusion list don't appear to work either.
    Cheers
    I don't think "primary visibility" was ever made to work for lights.
    The exclusion list, however, should work just fine - for example the vrayobjectproperties can be assigned to a geometry object, then a light can be placed in the exclusion list for reflections and the light won't be visible in this object's reflections, but still visible in other objects' reflections.
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      Cheers.
      The exclusion list doesn't appear to be working.
        Originally posted by sherridge101 View Post
        Cheers.
        What V-Ray and Maya versions are you using?
        Heres's a sample scene of the setup - does it differ from yours? vop_reflection_exclude_lights.zip
        Alex Yolov
        Product Manager
        www.chaos.com
          Cheers for the scene - The 'vrayobjectproperties' hides the lights from the geometry successfully.
          This isn't working on my scene - I am using VRaySoftbox and parenting the light to a locator.
          I'm using 27382.
          On your scene, the geometry is hidden from all light reflections. Is it possible to hide certain lights from the geo and not others?
          Cheers
            That's practically the idea - I've put all my lights into the exclude list, but you can put just some of them. Can you share a scene that we can look at?
            Alex Yolov
            Product Manager
            www.chaos.com
              Cool, just sent a link to a scene.
              Cheers
                Got it, looking into it now.
                Alex Yolov
                Product Manager
                www.chaos.com
                  I got a look at the scene, here's what I changed to make it work: to exclude a light from an object's reflection, the object needs to have vrayObjectProperties and within those, the reflection exclude list needs to be enabled. The light goes into the exclude list, not in the vrayObjectProperties. To disconnect the light from the vrayObjectProperties, I've used the set editor (vrayObjectProperties is a set as far as Maya is concerned).
                  I sent you a pm with the modified scene. Let me know if that's the result you were after.
                  Alex Yolov
                  Product Manager
                  www.chaos.com
                    Great, thanks Alex.
                    I didn't think to use the Relationship Editor for light linking.
                    Cheers
                      It's not light linking per se. The vrayObjectProperties includes objects to apply properties to just like a Maya set. Adding objects is easy in the outliner, but removing objects requires using the set editor.
                      Alex Yolov
                      Product Manager
                      www.chaos.com
