Baking light
  • Baking light
    Is there a way in maya, using vray, to be able to bake out the lighting and colour of an object? I'v managed to get one frame out and a uv set from this, but what i'm after is a sequence?
    I have an object that has lights flashing on and off over the surface, i need to bake this out into a Uv sequence to then be able to put bake on the object as a shader?
    Any help with this?
    Cheers
    You can do this if, beside the baking engine, you also enable the animation in the Common tab of the Render settings,
    Miroslav Ivanov
    Chaos Cosmos
