Rendering product labels with text (a little blurry)
  • Rendering product labels with text (a little blurry)
    Can anyone recommend the best anti-aliasing filter (or settings) for rendering products with type/text on them? I used to use 3DS Max and my labels were always nice and crisp and clear. I've tried every filter setting in Vray for Maya but can't get the same clear renders out of Vray/Maya. My texture maps are 600 dpi at 4000x4000 pixels so that should not be the reason. Any suggestions would be greatly appreciated!
    Maya's default quadratic file filter is too blurry , I usually set it to off , have you tried that?
    https://www.artstation.com/damaggio
      Ditto, turn off filtering for text. But whether your texture resolution is sufficient depends entirely on your output resolution and the texture's proximity to the render camera. The software can't create pixels in the texture map for you, so if you get super close to even a 4K texture at a massive resolution (e.g. 16K for something like a print ad), you may still encounter blurriness. Also, FYI, DPI is meaningless in CG, that's a print output spec.
        Yes we turned off quadratic a few months ago and that did help (thank you!) I guess I am questioning the clarity since I was using Mitchell Netravali filter in Max and getting crisper text than in Maya. It's a bit frustrating.
          You can get sharp filtering with Lanczos. Do not filter textures in this case.
          Dmitry Vinnik
          Silhouette Images Inc.
          ShowReel:
            I did more testing and it seems that the Catmull-Rom filter is making the text sharper, so I'm going to stick with that. Thanks for everyone who commented!
