Access Shadernames in Vray Proxy
  • Access Shadernames in Vray Proxy
    is there some way to access the shader names stored in a Vray Proxy with Python or MEL?
    I would like to connect shaders based on name to a VRayMeshMtl.
    And what does the attribute "Assign shaders by name" in the VRayMeshMtl do? It is not explained in the documentation.
    Thanks, Florian
    Florian von Behr
    CG Supervisor
    The Scope GmbH
    Behance
    For the moment, you can use the ply2vrmesh command-line tool with the -info option to extract the information.
    The option to assign by name is helpful if the .vrmesh/Alembic file is updated on disk with a new revision that sometimes has the objects reordered.
      Thanks.
      I'll try to script that.
      I guess access to the shader names in a vray proxy is a feature request then
      Cheers, Florian
      Florian von Behr
      CG Supervisor
      The Scope GmbH
      Behance
        It's already exists!
        When you import VRayProxy it creates with connected VRayMeshMaterial. And you can read all info from it.
        Like this.
        Code:
        vrProxyDAG = 'mesh' # your vrayProxy node name (transform node)
        vrProxyShape = cmds.listRelatives(vrProxyDAG, s=True)[0]
        vrProxyMesh = cmds.listConnections(vrProxyShape + '.inMesh')[0]
        vrProxyMaterial = cmds.listConnections(vrProxyMesh + '.fileName2', type='VRayMeshMaterial')[0]
        for index in range(0, cmds.getAttr(vrProxyMaterial + '.shaders', s=True)):
           print cmds.getAttr(vrProxyMaterial + '.shaderNames[{}]'.format(index)) # shader name
           print cmds.getAttr(vrProxyMaterial + '.shaders[{}]'.format(index)) # shader value, here you can connect your shader.
          Cool! Thanks.
          Almost finished my code where I launch ply2vrmesh.exe and parse the output. but this is much more simple. Guess I still learned alot
          Florian von Behr
          CG Supervisor
          The Scope GmbH
          Behance
            Hi guys,
            I am trying to write something that will allow me to automatically connect shaders that already exist in the scene with the same names as those in the shader list of the proxy. The above is very useful, thanks for sharing.
            I am however a novice when it comes to scripting so was hoping that someone would be able to lend a hand and offer any pointers on how best to achieve what I want to do?
            Thanks in advance,
              here is a basic script that connects shaders with identical names to the VrayMeshMaterial. It works on either a selection or all VrayMeshMaterials in the scene.
              Code:
              import maya.cmds as cmds
              def assign_shader():
                  This method connects shaders with the same name to a VRayMeshMaterial.
                  If something is selected, it works on the selection, otherwise it works on the whole scene.
                  Author: Florian von Behr f.vonbehr at thescope.studio
                  Installation:
                  Copy the script to your Maya script directory.
                  Load it in Maya with this command from the script editor:
                  import vrayProxyTools.py
                  vrayProxyTools.assign_shader()
                  vray_proxys = cmds.ls(sl=True)  # vrayProxy node name (transform node)
                  # if nothing is selected
                  if not vray_proxys:
                      # get all VRayMeshMaterial in the scene
                      vray_mesh_materials = cmds.ls(type="VRayMeshMaterial")
                      print vray_mesh_materials
                  # if something is selected, get the VRayMeshMaterials from the selection
                  else:
                      vray_mesh_materials = []
                      for proxy in vray_proxys:
                          vray_proxy_shape = cmds.listRelatives(proxy, s=True)[0]  # get the shape node
                          vray_proxy_mesh = cmds.listConnections(vray_proxy_shape + '.inMesh')[0]  # get the proxy node
                          vray_mesh_materials = cmds.listConnections(vray_proxy_mesh + '.fileName2', type='VRayMeshMaterial')  # get the shader
                          vray_mesh_materials.append(vray_mesh_materials[0])  # add shader to list
                  # if the list of shaders is emtpty
                  if not vray_mesh_materials:
                      print("There are no VRayMeshMaterials in the scene.")
                  else:
                      for material in vray_mesh_materials:
                          cmds.setAttr(material + ".assignShadersByName", 1)
                          for index in range(0, cmds.getAttr(material + '.shaders', s=True)):
                               # get the shader name
                              shaderName = cmds.getAttr(material + '.shaderNames[{}]'.format(index))
                              # check if a shader with that name exists in scene
                              if cmds.objExists(shaderName) is True:
                                  # and then test if it is already connected
                                  if not cmds.isConnected(shaderName + ".outColor", material + ".shaders" + "[" + str(index) + "]"):
                                      # if not, connect it
                                      cmds.connectAttr(shaderName + ".outColor", material + ".shaders" + "[" + str(index) + "]", f=True)
                              else:
                                  # If a shader with the name does not exist, let the user know which shader
                                  print "Shader {0} is missing!".format(shaderName)
              Florian von Behr
              CG Supervisor
              The Scope GmbH
              Behance
                And if you want to learn scripting, I can really recommend this tutorial: https://www.udemy.com/python-for-maya/
                Florian von Behr
                CG Supervisor
                The Scope GmbH
                Behance
                  Hi Florian,
                  Thats very helpful and kind of you. Thank you for the script and for the link to the scripting tutorial, I will surely check that out.
                  Thanks again.
