Best advice for rendering through walls?
  • Best advice for rendering through walls?
    Usually I can hide or extend the wall although since there is a mirror against the back wall, i would like to retain the wall in the reflection.
    I have tried,
    -Messing with the Near Clip Plane = Renders Black
    -Unticking Double-Sided in Maya's Render Stats whilst also deleting the back-faces = Renders Black
    -Unticking Double-Sided in the VRay Material Options whilst also deleting the back-faces = Renders the wall with a translucent effect.
    I have attached an image of my scenario,
    Any help is appreciated,
    Regards
    Go into the object properties and untick "visible to camera."
    Edit: oh its Maya. My suggestion was for Max, sorry.
    German guy, sorry for my English.
      The principle is the same in Maya. Create an object properties set, then disable "visible to camera"
      __
      https://surfaceimperfections.com/
        Thanks for that. Whilst I was trying to find the visible to camera option, I found that disabling Primary Visibility in Render Stats was the solution I was after. I must have missed that function in the beginning.
        Regards,
          But near clipping plane should work also. I'm using it very often.
          www.mirage-cg.com
