Vray Triplanar into Texture Deform node
  • Vray Triplanar into Texture Deform node
    I may be trying to fit a square through a circle here, but has anyone found a way of plugging the vray triplanar node into the texture deform node in maya. The reason for this is that i actually want to deform a high poly object using the control that vray offers. Using the maya projection node in triplanar doesn’t give any blending control between a height map from each axis and jus gives a solid hard edge, very ugly blending.
    I am actually hoping i be able to deform a terrain with a tiled displacement map from substance, further filtering this with a splatmap to certain areas, such as rock faces and then blending in a triplanar manner. So maybe there is a node or two to place between to get the two to work?
    Thanks
    The VRayTriplanar won't work there. I'll make a note for the devs to look into whether this is possible at all. You can refer to VMAYA-7726 for more details in the future.
    Is it an option for you to use displacement instead of texture deformation? The triplanar won't work directly as a displacement map, but if you hook it through a ramp it will work (not sure if it's not just a coincidence that it does, but it does).
    You won't have any sort of viewport preview, though.
    The simple setup would be: create a ramp, delete all but one positions, connect the triplanar to that position, then connect the ramp as displacement.
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      Hi Yolov,
      Thank you, I will give the ramp node trick a try. Unfortunately i need to actually displace the geometry and not just at render time. I completely understand that this is not fully supported it was just that the brilliant options your triplanar node has gives a next level of control to anything else. I think i may have been trying to be too clever in one move.
      I just found a workaround, alternate method which is to project the triplanar heightmap, but then use the vray to bake out a diffuse pass as exr across the UV’s. I was then able to apply this texture image file to plug into the texture deform node with success. I still need to tweak to get the best out of this. Thank you for the ramp trick as well, i will try this out, as it may work directly as well, completely cutting out this step.
      The idea is to apply this to a super high poly terrain so the displacement detail is captured, filter by a splatmap to target only rock faces for example, then decimate the terrain to a poly friendly amount. I am hoping a really fast method of detailing and texturing large environments.
      Thank you again for the advice
      Much appreciated.
        Ah, I didn't think of baking it, that sounds like a good solution, although any tweaks will require re-baking. With the ramp, you could do an IPR to tweak the settings until you're happy and then either use it as is or bake it.
        Alex Yolov
        Product Manager
        www.chaos.com
          Thanks Alex,
          I will give that a try, great idea with the IPR.
