Maya 2017 Vray water height mapping
  • Maya 2017 Vray water height mapping
    Hi there,
    I'm trying to map the wave height in vray water by a map, but nothing works- even if I plug a simple checker, it just removes the displacement all over the plane.
    Any ideas?
    Thank you for reporting that. I have added this as a bug to our system.
    As a workaround, you could try using PhoenixFDOceanTexture instead of VRayWater. If you don't have PhoenixFD you could download a trial and use the Ocean texture as much as you like.
    Nikolay Kusht | chaos.com
    Team Lead, 3D Support | contact us
      Or create the ocean texture from vray plugin (Create > VRay > Create from VRay plugin > Textures > PhoenixFDOceanTex).
      Alex Yolov
      Product Manager
      V-Ray for Maya, Chaos Player
      www.chaos.com
        Thank you for the answers! I actually found a workaround- turns out in maya there's a plugin called lookdev toolkit, and once active it has a few more shading nodes- one of them is a colorMath node, which basically allows you to multiply RGB vector map by simple 8 bit 0-1 B&W map and plug the result into the displacement map- and it works!
