No render settings panel after install??
  • No render settings panel after install??
    Just installed Trial NEXT and I am getting this error
    "Cannot find procedure "unifiedRenderGlobalsWindow".
    Start of trace: (command window: line 1).
    unifiedRenderGlobalsWindow (command window: line 1)."
    I uninstalled and reinstalled but still no settings panel.
    Is this VRay install related?
    I'll keep trying
    It might be, I can't really say. Can you copy-paste the error message as it appears in the maya script editor?
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      Have you tried deleting your Maya old preferences and let the install create a new vanilla one for you? Lot of times the issue is preferences related.
      always curious...
        Probably not helpful this, but I recently lost the render settings tabs, when messing around with my maya.env file. So the tabs appeared but there was nothing in them. I think it was due to another plugin not loading correctly and blocking it or something like that. If you have any, try disabling them.
        e: info@adriandenne.com
        w: www.adriandenne.com
          Well I couldn't solve it so the only and quickest way to fix it was to reinstall maya.
          job done.
