Vray Clipper with Dirt Element
  • Vray Clipper with Dirt Element
    Hi guys,
    Is there a way to make the V-Ray Clipper work with a Extra Tex element with the dirt map applied? Whether I use either just the standard clipper or a mesh clipper, the dirt pass doesn't seem to take note of the clipped mesh with it's shadowing/occluded areas.
    Running Windows with Maya 2018 with Vray 3.6.04
    Could you give us an example of what exactly you are trying to achieve? Screenshots would be useful.
    Nikolay Kusht | chaos.com
    Team Lead, 3D Support | contact us
      This might show a little better how it's working for me: I was trying to do a reveal of the layers of a tyre by using VrayClipper to remove the outer rubber. When the VrayClipper clips the outer layer the dirt pass is still rendering the shadow/occlusion as if the tyre's outer mesh had not been clipped.
      Its not anything urgent, I've gotten around it by using matte layers to mask out the unwanted areas. I thought it might be a bug however...
        Thank you for the provided shots. I have made a few tests and it seems that the issue is not present and working as expected in V-Ray Next.
