You shouldn't worry about this error it is a known issue and it's is a bit hard for fixing. It occurs mostly when Maya software or another render is the default one. We have quite a lot of older threads about this error and I can assure you that this isn't casing the issue with the camera.
Since you spoke for starting V-Ray from network location does this mean that you're using V-Ray from zip installation not the one with the installer even on the local machine?
