I've run into this error before in the past where the render settings with Vray do not get setup properly and consequently appear missing, hidden or mulched in the render setting window in Maya 2018.5. But this time deleting the prefs folder does nothing, nor does the script:
deleteUI -wnd unifiedRenderGlobalsWindow;
buildNewSceneUI;
When I open a shared file that someone else has worked on who doesn't use VRAY I get these errors.
// Error: file: C:/Program Files/Autodesk/Maya2018/vray/scripts/vrayUIUtils.mel line 438: No object matches name: vraySettings.hideRVOn //
// Error: file: C:/Program Files/Autodesk/Maya2018/vray/scripts/vrayCreateCommonGlobalsTab.mel line 544: Could not find attribute named "vraySettings.fileNamePrefix" //
// Error: file: C:/Program Files/Autodesk/Maya2018/vray/scripts/vrayCreateGlobalsTab.mel line 747: Could not find attribute named "vraySettings.renderMaskTexture" //
// Error: file: C:/Program Files/Autodesk/Maya2018/vray/scripts/vrayCreateIndirectIlluminationTab.mel line 67: No object matches name: vraySettings.giOn //
// Error: file: C:/Program Files/Autodesk/Maya2018/vray/scripts/vrayCreateSettingsTab.mel line 359: No object matches name: vraySettings.sys_distributed_rendering_on //
// Error: file: C:/Program Files/Autodesk/Maya2018/vray/scripts/vrayCreateOverridesTab.mel line 1417: Could not find attribute named "vraySettings.cam_envtexBg" //
// Error: file: C:/Program Files/Autodesk/Maya2018/vray/scripts/vrayCreateGlobalsTab.mel line 594: No object matches name: vraySettings.productionEngine //
// Error: file: C:/Program Files/Autodesk/Maya2018/vray/scripts/vrayCreateRTTab.mel line 13: No object matches name: vraySettings.rt_traceDepth //
How can I make this function properly?
buildNewSceneUI;
