Polygon facets appear when Bump Mult is set to 1.0 or higher in the openSubdiv model with normal map.
  • Polygon facets appear when Bump Mult is set to 1.0 or higher in the openSubdiv model with normal map.
    Is there a way to work around other than adding more subdivs?
    Confirmed with V-Ray Next Maya Update 1.1
    attached example file
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    Is this a Bump shadeing problem on low polygons that hasn't been solved for a long time?
    oakcorp.net
    v-ray.jp
      Thanks for the report and the provided files. We are aware of the issue, it is logged in our system (Bug-tracker id: VMAYA-8484) for our developers to investigate. Increasing the geometry's subdivisions indeed reduces the starkness of the facets and can be used as a workaround.
        Thank you for adding to Bug-tracker.
        I hope that this problem will be solved soon.
        oakcorp.net
        v-ray.jp
          Actually I could not reproduce the issue in Update 2 with the scene that you provided, but I will look again.
            Oh, yes, the problem is gone with Update 2.
            Thank you!
            oakcorp.net
            v-ray.jp
