Crashing when performing certain operations inside of a VRayOSLTexture node
  • Crashing when performing certain operations inside of a VRayOSLTexture node
    V-Ray for Maya version: V-Ray Next for Maya, update 1 (v4.12.01.29159 from May 8 2019)
    Maya version: 2019.3
    I grabbed an OSL shader written for 3DS Max from here:
    https://github.com/ADN-DevTech/3dsMa...iWindowBox.osl
    But it causes V-Ray to crash. I have simplified it to demonstrate what I think is causing the crash:
    Code:
    shader jiWindowBox_Max
    string filename = "missingcolor",
    output color result = color(0.0),
    color finalRGB;
    color objI = transform("object", -I);
    objI = -objI;
    color objP = (color(u,v,0.5) * 2.0 - color(1.0)) * 0.5 + color(0.5);
    color sections = step(0, objI);
    color baseDepth = (objP-sections)/(-objI);
    color baseDepthX = (objI*baseDepth[1] + objP + color(1.0));
    color baseDepthY = (objI*baseDepth[0] + objP + color(1.0));
    float horizU = baseDepthY[2] - 0.5;
    // works
    // finalRGB = color(horizU);
    // doesn't work
    finalRGB = color(clamp(horizU, 0.0, 1.0));
    result = finalRGB;
    In the above example, outputting "horizU" directly seems to give the correct result - but modifying it in any way appears to lead to a crash.
    Has anyone seen this before?
    Thanks for the report. I'll try to debug it.
    Ivan
      Thanks for looking into it! Would be great to have a fix
        I could not reproduce the crash (tried with all variants of the minimal shader and even with the original one) and I begin to suspect there is something to do with the backend codegen and the specific CPU. Any of the following would help to narrow down the issue:
        1) Your exact CPU model. We've encountered similar crashes with Xeon Gold/SIlver/Platinum/Bronze in the past.
        2) Any crash dumps and even plain V-Ray log files.
        3) Any exported vrscenes would be helpful too.
        Ivan
          Hey Ivan, sorry for the late response, and thanks so much for looking into this!
          It is in fact running on an Intel Xeon Silver 4114 CPU @2.2GHz.
          Unfortunately as it's a work thing getting any files to you is a little difficult, but I'll look into it.
          Thanks, Shane
            Thanks! That's already more than enough. I'll check if it is possible to backport any of the Xeon fixes back to 4.12.
            Ivan
              Hey Ivan, just curious if there are any updates on this?
                Hello Shane, I'm sorry about the delay. I'm working on porting the required patches to 4.12. I'll notify you, once I have a working test build for Maya 2019.
                Ivan
