New Stochastic tiling node does not work with displacement
  • New Stochastic tiling node does not work with displacement
    I can't get displacement map to work with stochastic tiling node, I wonder if it's a bug or something which was too difficult to implement for now?
    kindest regards,
    Karol
    My Artstation
    Whether it is an advantageous position or a disadvantageous one, the opposite state should be always present to your mind. -
    Sun Tsu
    As you can see both texture nodes are connected to the same UVWRandomizer node with StochasticTiling ON.
    My Artstation
    Sun Tsu
      It works well in NormalDisplacement mode, although it breakes once set to 2D Displacement.
      My Artstation
      Sun Tsu
        Hello,
        I also had this Problems for a while. I just figured out that if you switch to Mode -> "By Object ID" and also give the different Objects an Object ID it works pretty well. I guess also "By Render ID". Displacement was always set to Normal Displacement because I render 90% with GPU.
        But like you figured out it works not like expected when you switch to 2D Displacement and CPU. I don't know why. But I don't have that much Experience with CPU Rendering Question is also why don't you render this Displacement it with Normal Displacement? Slower?
        Cheers
        Tobias
          I just saw that it also works with 2D Displacement. My Camera Angel was Top Bottom so I didn't really saw it that good, haha
            Refer to this post by vlado for an answer.
              Originally posted by tobiasroesli View Post
              Hello,
              Hi Tobias, I find 2D displacement to have better quality
              Here are the docs: https://docs.chaosgroup.com/display/...cement+Control
              regards,
              Karol
              My Artstation
              Sun Tsu
