Vrayobjectproperties set does not work in RenderLayer
  • Vrayobjectproperties set does not work in RenderLayer
    Using vrayobjectproperties set with RenderLayer's Collection does not work properly.
    What's wrong?
    Confirmed with V-Ray 5.1 with Maya 2022, 2020
    Check out the screen recording.
    https://drive.google.com/file/d/14_7...VofkL-YRAHP4p/
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    Are vray object props meant to work that way? I mean, theyre defined as sets, but Ive always assumed I needed to actually add the geo to a collection also.
    Website
    https://mangobeard.com/
    Behance
    https://www.behance.net/seandunderdale
      The collection of geometry does indeed work.
      What I want to make sure is that this operation works fine in Maya 2018.
      (A customer of ours who migrated from Maya 2018 to Maya 2022 reported this issue.)
      It does not work in Maya 2019 or later.
      Is this a problem on Maya's side?
      oakcorp.net
      v-ray.jp
        Indeed, it does work on Maya 2018. I've logged the issue (internal bug-tracker id: VMAYA-10793) for developer investigation.
          Thank you for adding to the log.
          oakcorp.net
          v-ray.jp
            Hey guys
            i never used the VROP with AOS or Render Layer !! I'll test it when they fix the bug !!
            Thanks ☺️
            Carlos Alvarez Velazquez
            Tutorials about VRay for Maya:
            https://youtube.com/CarlosAlvarezVelazquez
