VFB input colourspace never stays to what I set it
  • VFB input colourspace never stays to what I set it
    Im using an supported rendering colourspace scene-linear DCI-P3 D65 (not sure why its an option). I found, that in combination with AdobeRGB display device, and Untonemapped view transform meant my backplates looked correct, and I could match easily in cg with no mismatches. Im sure my workflow is incorrect, but I get the results I need. I also found in a recent full cg job that some shaders like a gold I made looked much better than it did in ACES. (Aces had a secondary bounce that was more orange, and my current setup looked far more like the gold I wanted). Now this is all fine, since it works, and it looks how I like, but the input colorspace always changes itself back to ACES, despite my efforts to set it to what I want. I know this menu is tied to the maya color prefs, so they change when the VFB settings change, but it never remembers it, and everytime I need to open a scene, I have to go change the input colourspace. If Im stressed, or its late, or Im multi tasking, sometimes I forget and my renders (and gols) comes out looking wrong.
    Is this intended behaviour, that no matter how often you change the input colourspace, to something other than aces, it always switches itself back upon scene re-open? Or do I need to change it in maya prefs for it to save to the scene, rather than changing it via the VFB? Ive attached a screen grab of the settings I like to use, and that work for me.
    Website
    https://mangobeard.com/
    Behance
    https://www.behance.net/seandunderdale
    Try using the environment variables from this thread. That should solve it.
      About matching a backplate, and the Orange cast on using ACES, I can help you with that if needed. If you have a chance to investigate tag me and we can solve this setup
      V-Ray only support ACEScg as an internal color space, the settings you used above are not optimal. And feel free to ignore if you already have the result you are looking for, PBR and color management rules are in place to help artists, it is not a big deal bending the rules for a certain look every now and then
      The environment variables Aleksander shared should solve the frame buffer issue, let us know.
      Best,
      Muhammed
      Muhammed Hamed
      V-Ray GPU product specialist
      chaos.com
        Cheers guys. I there somewhere I can get the correct formatting for the env variables? Or can I copy the text verbatim from the VFB and that would work ok?
        Website
        Behance
          Copying the naming from the config file should work.
