VRmatconverter error upon converting
  • VRmatconverter error upon converting
    I am at somewhat of a loss with this one honestly and could use some insight. I am trying to convert materials in Maya to be imported into Max, so the obvious choice is the VRMat Converter. I click on the icon in the V-Ray toolbar. The dialogue box appears. It finds the shaders, I select them and click convert and receive the following script error:
    # Error: file: C:/Program Files/Autodesk/Maya2022/vray/scripts/vrayVRmatConverter.mel line 162: NameError: file <maya console> line 1: name 'reload' is not defined #
    I have tried creating a very simple shader using only 1 bitmap as well and I receive the same error.
    I have tried this in Maya 2022 as well as 2023 with the same error resulting each time. Any help with this is greatly appreciated.
    I get the same error as well! Look like a bug
      Yeah, it seems like it's a naming error in the scripting that might be an easy fix, but I could be way off base.
      Does anyone know of a fix for this?
        Thanks for the report. We already have it logged (internal bug-tracker id: VMAYA-11028 ). I'll notify the developers about it.
          Thank you for letting me know. Hopefully a resolution is provided soon.
            Sorry to say, the VRayVRMat converter is pretty old and its future is uncertain. Another way of transferring shaders is through a .vrscene, which is then loaded in the VRayVRMatMtl.
              Right, I have successfully exported scene materials applied to geometry within a .vrscene. However, I need to export the shaders/materials alone that can be then saved out to it's own library once in Max. Losing the ability to edit and or apply them within a new scene is a deal breaker, but it's possible I missed something on my first try.
