Hello Chaos team,
I believe there's still a problem with the Env Fog, I'm sending the scene to support. Maya 2022 Windows 10
Basically the fog density disappears at a certain point way before it reaches a value of zero, same thing if you wanna make the fog thinner by increasing the distance value, at a certain increased value it just vanishes (IPR and CPU renders) no GPU tested.
The Transparency slider also, it works for a while as you reduce it and then... suddenly vanishes.
The issue happens at certain value numbers but not necessarily what I have in this image.
Ideally the fog should decreased in density slowly until is barely visible at very low values closer to zero.
See the attachment test and will send scene to be examined. Haven't tested in 2023
Vray 5 V-Ray 5 for Maya, update 2.3
(v5.20.03, revision 31756 from Nov 23 2022)
Maya 2022 Windows 10 RTX2800 GeForce
