Vray Displacement not working on nCloth
  • Vray Displacement not working on nCloth
    When creating a Substance node and generating a Vray workflow node network and applying that material to a plane, i then have to add the Vray attribute Displacement Control to lower the height of the height map and then it looks great. But when i convert the plane to nCloth and sim it, the displacement reverts and the Vray Displacement Control attribute no longer works. Is there a way to get the Vray Displacement Control working again on simmed nCloth geometry? Examples bellow.
    Vray Displacement Control attribute settings
Name:	Screenshot 2023-04-16 184306.png
ID:	1178182 Click image for larger version
Name:	Screenshot 2023-04-16 184209.jpg
    I posted earlier and suggested it might be that your rendering object after nCloth creation was a different one to your original object. Now just did a quick test and can see that isn't the case. Seems like in Maya 2020 at least any Vray attributes get stripped off during nCloth creation, and there isn't even the capability to add them back afterwards (the normal Vray extra attrs. menu is completely missing on the shape nodes). Not sure why, but you can add a Vray displacement node to your output cloth and get your displacement back that way. This is a more versatile workflow anyway, as it creates a set that you can drop objects in and out of easily, rather than dealing with extra attrs. on each one (depending on the situation of course).
