weird artefacts with sky clouds
  • weird artefacts with sky clouds
    hi,
    pretty new to vray and i played a bit with the prg clear sky and the procedural clouds.
    when setting the clouds density to 1, i get strange repetitiv patterns in the clouds, lines going towards the sun center...
    is this a known issue?
    Could you share a screencap?
      here a screenshot of this, it gets obvious when cloud density gets more and more toward 1. it seems to be relative to the sun position...
      i am using her vray GPU, but it is the same with CPU....
      Click image for larger version  Name:	vray_cloud_pattern_bug.jpg Views:	0 Size:	278.5 KB ID:	1191059
        I presume that's simply the pattern getting exposed due to the high density of the clouds. Playing around with the density multiplier, variety, and thickness parameters should mitigate the effect. Note that additional parameters were added in V-Ray 6 for Maya, update 1.
