bumpToGloss not supporting UDIMs
  • bumpToGloss not supporting UDIMs
    i noticed a bug in vray's bumpToGloss where it doesn't respect the Maya File Node "UV TIle Mode" Attribute.
    Below you can see the result of bumpToGloss when using the UDIM Mode.
ID:	1195706 Click image for larger version
    If instead I set the UV Tile Mode to OFF and manually enter the <UDIM> tag into the filefield, than it works
    There should be a warning in the log about this. Quoting the log message from my tests: "Warning: VRayBump2Glossiness does not support textures with tags in the filename"
      I rarely see production assets that are not relying on <UDIM> tiles these days. Is missing support for this a temporary limitation?
        I only see the warning "Warning: VRayBump2Glossiness does not support textures with tags in the filename​" if I manually add the <UDIM> Tag into the File Text Edit Field.
        If I set the text edit field to File.1001.exr and then change the Tiling Mode to UDIM, Maya swaps out the the 1001 for <UDIM> however the warning about it no longer appears.
        This is because Maya maintains two filename attributes, the original one and the one that the Tiling Mode sets.
        I suppose Vray only checks the Main one which remains at File.1001.exr
        All that being said, it is a serious limitation as was mentioned by Dan above, not having UDIM Tile support for this makes it rarely usable.
          Spoke with the devs about it - it is unsupported, but it will be fixed eventually.
