I have a maya 2022.3 vray 5.2.1 scene with references. Whenever i try to create a render setup Layer I get this errors:
// Error: file: C:/Program Files/Autodesk/Maya2022/scripts/others/createMayaHardwareGlobalsTab.mel line 185: Object 'scrollLayout' not found. //
after that the Tabs are broken on the Master Layer. The Maya Hardware especially as you can see in the screenshot.
Now when I try to submit to the farm (royal render) i get mixed render submissions/settings, one layer rendering .png (hardware render),the other one .exr (vray) even though vray is detected as render engine.
his i a really big problem for us.
I tried reproducing the error in another maya session but there everything works there. So it must be scene specific and not a faulty installation or maya pref.
What I tried so far:
I have seen multiple user posts describing as similar problem with the Common Tab also related to Arnold.we don´t have Arnold installed.
https://forums.autodesk.com/t5/maya-...8442542#M66504
To me it looks like some of maya mel commands and vray don´t work properly together.
any help appreciated!
- unloading references
- changing the preferred renderer
- unloading vray
- deleting vray settings in the outliner
- importing the scene into an empty new maya session
- clean up references
- deleting unknown nodes
- removing as many plugins as possible
- cleaning any remains after removing the references
