Motion blur doesn't work with Chaos Scatter
  • Motion blur doesn't work with Chaos Scatter
    As the title says
    Bottom row is instanced cubes on a curve with animation expression in offset of the scatter. Top row is geo with keyframes.
    As you can see MB works fine on the top row.
Name:	Screenshot 2024-06-11 142038.jpg
    Hi, thanks for posting. What do you mean by "animation expression"? I've tested a setup with a scatter and animated cube and it as motion blur. Do you mean that you animate the scatter parameters for example the translation?
    Vladimir Krastev | chaos.com
      Click image for larger version  Name:	download?id=14icCp6yuNAM_i5cpodJRsIOrnBm4z71g&authuser=0.png Views:	0 Size:	280.6 KB ID:	1210137
      ChaosScatterShape1.splineOffset = time;
      Yes, of course instanced geo with keyframes on it will produce MB because it calculates the mb from the original geo that has keyframes on it, but if you animate parameters in the scatter it will not work.
      Here I have done the same that you've done.... Keyframed the cube, and THEN instanced it through scatter. and then there's MB.
      Click image for larger version  Name:	Screenshot 2024-06-11 151447.jpg Views:	0 Size:	68.5 KB ID:	1210139
        Hi, the motion blur does not work if I animate the scatter parameters for example the translation.
        Any other parameter like rotation etc. does not produce motion blur either. This is not the case with 3ds Max. Animating the Scatter parameters produces motion blur in 3ds Max.
        I will investigate this further and get back to the thread.
          Thank you Vladimir
            Any news on this?
              Hi, the issue is logged as feature request in our system (VMAYA-12949). We will notify you after it is resolved.
                Just tested this (i.e. animating ChaosScatter offset) and it seems to work as expected in the V-Ray 7 beta builds.
