Hello, we are having problems getting motion blur on scatter objects when target object is animated - in this case rotates around it's axis. This is the simplified scene for illustration - the cube that's used as a base target object is rotating around it's y-axis and has motion blur, while clumps of grass that are scattered on it surface refuse to be motion blurred. We really need this to work - is there any workaround? Thanks in advance
Problems with scatter and motionblur
An ̶i̶m̶p̶r̶o̶v̶e̶m̶e̶n̶t̶ ̶r̶e̶q̶u̶e̶s̶t̶ ̶ for this is already logged (internal bug-tracker id: VMAYA-12949) as Twist mentioned. Will test to check if there are workarounds.
EDIT: Actually, this seems like a bug: there is no motion blur on scattered objects when the target object is animated. Updated the log. I'm not sure if there are ways to bypass it at this point, except of course converting the scattered objects to instances (Covert to Maya instances button in the Scattering rollout) and animating them too.Last edited by hermit.crab; 18-12-2024, 01:44 AM.
Originally posted by hermit.crab View PostAn improvement request for this is already logged (internal bug-tracker id: VMAYA-12949) as Twist mentioned. Will test to check if there are workarounds.
