multimatte id on vray mtl crashes vrscatter
  • multimatte id on vray mtl crashes vrscatter
    multimatte id on vray mtl crashes vrscatter when i drag geo into scatter
    link to video highlighting issue below
    https://www.dropbox.com/scl/fi/palyo...152lv2k69&dl=0
    test scene beloe
    https://www.dropbox.com/scl/fi/uyvxh...r20gp14nuu7&dl =0
    maya 2023
    V-Ray 6 for Maya, update 2
    (v6.20.01, revision 32526 from Mar 28 2024)
    also same is exhibted on a firends computer maya 2024 and a different version of vray
    The issue must be something different because I’ve done this many many times
      Weird it done it on another completely unrelated workstation when I messaged about the problem to a friend, too much of a coincidence. Maybe it's a particular build. Did u watch the video and try the test scene. What version of vray, Maya and os u running. Thanks
        Can confirm. I tested the same simple setup, and maya 2024, vray 6 crashed the simplest of scenes when using a material ID on a shader...then applying that to an object, then adding that object to a scatter.
        Website
        https://mangobeard.com/
        Behance
        https://www.behance.net/seandunderdale
          Thanks for the report. The issue is reproducible in V-Ray 6, however, it seems to be fixed in the V-Ray 7 beta builds. I'll check if we can pick the fix in the V-Ray 6 stable builds.
            thanks, object id on geo to create ids works for now
            cheers
            matt
