RTX and CUDA not reading custom attributes - VRAY7
  • RTX and CUDA not reading custom attributes - VRAY7
    I forgot to report this when Vray 7 was in beta but one of builds broke the functionality to read custom attributes from an Alembic file. This was working fine before.
    CPU works fine but RTX and GPU does not. Please fix this asap this an important one.
    PS it actually does not even render if is using a simple vray material either.
    Thanks
    FILES
    https://we.tl/t-XMN8HlSWw7
    Thanks for the report. Logged it (internal bug-tracker id: VGPU-6744). I'll notify the product owner to prioritize it.
    Originally posted by hsz View Post
    PS it actually does not even render if is using a simple vray material either.​
    It does, you just need to remove the override and use the new "Force default material" option (it uses the shader applied to the proxy).
      Any word on a fix?
        Not quite yet. The product owner has assigned it to a dev though.
          This is happening in Maya / Houdini btw so hopefully the fixed solve both.
