instances don't work in USD from Houdini to Maya, memory through the roof
  • instances don't work in USD from Houdini to Maya, memory through the roof
    I have made some assets in Houdini that contain a large number of instanced foliage ... pine needles on tree branches and garlands or full trees on some assets. I export these as USD scenes and load them in Maya and render with Vray 6.2.2 Everything renders correctly, but we're hitting a memory ceiling with these assets, as it seems that none of the instances are being instanced but considered as unique geometry. So where one asse should be taking memory of under a 100 Mb, I get about 25 Gb or more depending on the asset. When we add a bunch of these assets to out layout scene, we hit memory limit and crashes our workstations. I tried to troubleshoot and see if I can get the instances to behave properly, but haven't had any luck so far. Any help would be much appreciated, thanks!
    are you bring those as .usd data? and load them into Maya usd? and if not how then? Using a proxy?
      I load it as USD from file in maya
        can you share a repro or something? also what version of Maya USD are you using? and M version?
          yup for sure. Where can I share this with you? I prepared a houldin scene and USD export. It's 60 Mb, so it won't let me upload it here as an attachment
            Could you send me the .usd as well? Either via DM or the contact form.
              Use we transfer https://wetransfer.com/
                hsz and hermit.crab I need emails to share the wetransfer uploads with you
                  sorry forgot that it can be done as a link https://we.tl/t-bX8MtdVPCg
                  The simple, quick and secure way to send your files around the world without an account. Share your files, photos, and videos today for free.
                    you can send to yourself and post the link here
                      Lighter at Flux here, just adding software we are running
                      Maya: 2024.2
                      V-Ray: 6.20.02
                      MayaUsd: 0.25.0
                      Windows: 11​
                        I did a quick loading of the usd file + duplicating a bunch of them. My guess is that you are not using the instanceable to true. Im doing in BF because is just fast but you can see the difference in of having instance set to true or not and how much memory is using.
                        So you can see when I duplicate the files with instanceable set to true the memory does not change or barely. but with false is def will increase quite bit depending on the asset.
                        Look at
                        static memory and dynamic
                        Click image for larger version  Name:	maya_ynR7H4n7wz.png Views:	0 Size:	1.11 MB ID:	1233117
                        Click image for larger version  Name:	maya_instanceNotTrue.png Views:	0 Size:	17.7 KB ID:	1233118Click image for larger version  Name:	maya_8pn32x96jl.png Views:	0 Size:	15.8 KB ID:	1233119
