VRay RT Bug :-)
  • VRay RT Bug :-)
    Hiho,
    first of all YEAH wohoo, thanks and YES.
    The RT beta is up and running I cannot find a way to switch to GPU mode, but all my CPU are running like crazy!
    I will start playing around and post everything here.
    1. Switching the smoothproxy inside maya causes a crash or makes the object invisible in Rt rendering.
    2. Changing visibility of groups with some lights inside has no effect. The lights still stay visible in the rendering.
    3. Changing the color gain settings of a filetexture connected into the GI/Ref or Refraction environment causes an error: V-Ray warning: Render host pslwst38 (127.0.0.1) is not responding
    4. Same error happens when I change the texture to another file.
    4. Rendering a scene with displacement is not possible. Same error as above.
    Thanks again!!!!!!
    Paul
    VFX Supervisor @ www.parasol-island.com personal website www.dryzen.com latest reel http://vimeo.com/23603917
    wow! what?! where did you get the RT beta?!
    /Bard
    www.hellobard.com
    Norwegian Broadcasting Corporation (NRK) - Motion graphics artist
      Show a screenshot Paul....
        Found it by accident in the nightbuilds from last night
          btw. It is working directly with a completely lit scene with a lot of rect lights, motion blur and a lot of geometry!
            haha...lucky you!!
            it seems like it's gone now (unless it's inside the rar)... ;(
            /Bard
            www.hellobard.com
              no it is in the VRay for Maya builds.
                hmmm.... it doesn't seem to be in the 2008 darwin release. I'll check the 2011 one at home then, i'm guessing that RT is using the VFB which isn't in 2008...
                Edit: oh it's in there! but i'm getting this error
                // Error: ERROR: Could not create plugin RTEngine ! //
                // Error: There was a fatal error rendering the scene. //
                Probably not quite ready for action yet
                /Bard
                www.hellobard.com
                  Well Vlado did say they would add it to the nightly once it reached Alpha. But, they didnt mention it in the release notes, so I didnt think it was there. Okay, now I wanna drive home on my lunch break and play with it.
                    looking at nightly builds now, dont see it maybe i dont have access? is this a separate installer for RT or does install with vraySP1?
                      Paul says it's inside the regular nightly build. No separate installer, no comment in release notes.
                        I Had a look in today and yesterday's build and didn't find it... Either it has been remove or I cannot find it in Maya.
                        Portfolio: http://www.cgifocus.co.uk
                          Try IPR render
                          @Vlado: How can I use my GPU for rendering? I cannot find any options so far
                            Originally posted by paulDryzen View Post
                            Try IPR render
                            You can't switch it on in this version yet.
                            • #15
                              ok, please let put that information into the release notes of the new builds after it is avaiable
