V-Ray outliner not visible ?
  • V-Ray outliner not visible ?
    Hi, Does anyone know why I can no longer see the v-ray specific outliner window when using Vray RT? Is there a toggle button or menu anywhere?
    Big thanks in advance
    Joe
    To open the outliner window go to Window>Outliner
    If you can't see it make sure it's not minimized somewhere, is it's not most probably the window is dragged out of your monitor view.
    To bring it back make sure the windows is selected (Window>Outliner), press Alt+Space, then pres "M" button and use the arrows keys to drag it back.
    Zdravko Keremidchiev
      Sorry Zdravko, This is rather embarrassing.. I meant to say OUTPUT WINDOW ... i.e the VRAY specific command prompt window, which shows while rendering.
      Are you able to change the title of this thread btw?
      thanks so much!
        Which OS are you using?
          Thanks Vlado, I'm using Window XP 64bit version
            Did you try the same workflow that I mentioned?
            Make sure the windows is selected (from the toolbar), press Alt+Space, then pres "M" button and use the arrows keys to drag it back.
              Hi Zdravko, yes I have however the output command prompt window does not even appear in the bottom doc panel !?
