layered texture node clamps displacement
  • layered texture node clamps displacement
    I cant use the layered texture node to mask 32 bit displacement. It seems to clip the displacement below zero. (I have terrain that I want to push down). Mentalray seems to handle it right so this might be a bug?
    Have you unchecked the "Allow negative shader colors" option?
      I also noticed that bahavior. seems like the "Allow negative shader colors" is not transported to the layered texture node itself. Been working around that stuff for a while now and didn“t get a satisfying result yet. also while dragging on any alpha channel while in rt causes maya to crash instantly. (only when using an added vraydisplacement node. Not when using the standard maya displacement node)
      best regards,
      sacha
        any news on that topic? we are runnin into this issue as well.
          We'll check it out... which blending mode are you using in the layered texture?
            Hi Aquazum,
            What V-Ray/Maya versions are you using? Also what OS are you running? We can't reproduce the crash with RT that you described and we need some more information about it.
            Thanks in advance!
            Alex Yolov
            Product Manager
            V-Ray for Maya, Chaos Player
            www.chaos.com
              The problem is still present in 2.25.01. If you simply take two 32 bit exr displacement maps which contain both positive and negative information and layer them using over mode with a mask, the negative info becomes clipped.
              [2013/May/19|15:13:43] V-Ray: V-Ray for Maya version 2.25.01, revision 22851 from Apr 5 2013, 02:24:28
              Dmitry Vinnik
              Silhouette Images Inc.
              ShowReel:
                Hi Dmitry,
                Yes, we did reproduce that one, thanks. We have trouble reproducing the crash that Aquazum was talking about in his post.
                Alex Yolov
                Product Manager
                www.chaos.com
